Spindles vs Lowering Springs
gfunko
Whats up all. Still trying to understand truck suspension a bit (used to the tuner scene) so please excuse the noobiness of this questions. Current vehicle is a 2013 Tahoe LT, completely stock with 22 ck375 and 285/45/22 wheels. I definitely know I want to go with a 2/3 drop but not sure which set up to go with. Do I have the option of using a spindle drop or lowering springs? I know using springs will require a camber kit, but does using a spindle require one? Lastly, will the rear require a camber kit also? Some post/videos I've seen seem to suggest that the rear can be done by just swapping out springs (without a spring compressor).
If this has been addressed before, please point me to right thread. Thanks again!
OHSIXX
Milwaukee
Hit up Tony-he will get you dialed in-great customer service too........
@NORCAL SS
A 2/3 is pretty straight forward
Drop spindles in front
Lowering springs in rear-you can keep autoride too(if you have it)
gfunko
gfunko
So will I need camber kits to adjust alignment?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Not if you use a drop spindle. Everything up front stays the same except the position of the hub. however, you'll need to get an alignment since you're disconnecting and reconnecting parts.
AZSCTACO
Phoenix, AZ
Depending on how many miles you have on the front struts.....you may wanna consider drop struts. No need for a camber kit....they use the stock springs.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Drop struts could still need a camber kit. Springs or struts could cause a need for camber kit. The only thing up front that wouldn't cause a camber kit is spindles
Bruizza
As already stated hit up NorcalSS. Belltech kit is what a lot of us have used for the 2/3 drop.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1) how many miles on the truck? main quwstion
here are 2 i did with the drop struts and camber kit in front NO spacers
http://www.tahoeyukonforum.com/threads/lowered-2-tahoes-today-man-long-day.60720/
Brian Woodiwiss
Solano County/Bay Area
I'll 3rd or 4th that comment. Tony knows what's up. Ordered my stuff, had it for me locally so I could pick it up. Got stuck mid install, walked me through it, installed and loving the 2/3 drop. Perfect ride height. Zero issues. Looks clean even on my stock 20s. Wheels next. Pics SOON. :)
Thanks again, Tony. :thumbsup:
