Spitting Coolant
Rivieraracing
Your water pump is probably failing, check out the bottom of your water pump, if there is coolant leaking from there (out teh weep holes) then you need a new pump!! Pretty easy install!!
ecordell
CordellDesigns.com
Merica
could have got a bad one........
is it getting hot? (the truck temp)
patniven
