Spohn users!!! Please read
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Had a guy bring his truck in today to go over the rear suspension. He bought the spohn arm kit along with my 6 inch rear set up and said the truck felt very loose. I ended up going thru the del sphere ends and they were very loose. If you buy the del sphere ends its worth buying the tool which is like 15 bucks. That way you can tighten the ends and makes truck much better.
When I do them i make sure to tigthen them down so when you put a screw driver thru the hole it takes some tension to move.
I ended up going thru all the arms on his truck and tightened the ends down. he drove it back home 80 miles and said truck feels 10x better a lot more responsive.
YOU DO NOT want the balls in the ends to move with your finger you want to have tension behind them.
DEL SPHERE TOOL
2006Cateye
