camaroz1985
- Joined
- Apr 15, 2015
- Posts
- 240
- Reaction score
- 121
I got a set of smoked Spyder LED tails for the Suburban and when I went to install them the wiring harness on the passenger side seems to be too short. I even tried disconnecting at the junction block under the truck, thinking I could plug it back in when I was done and had the tail light bolted in place, but it is too short for that.
Have others found this, and if so what have you done? I could cut the harness and lengthen it, but I feel like I shouldn't have to do that to make these lights work, they should be plug and play. I was wondering if maybe the tail light harness from a Silverado would be any longer and hopefully have the same plugs on both ends.
