Squeak when going over speed bumps
Rangel
Great State of Texas
as the rear tires come off the speed bump and the rear bounces there is an annoying squeak. shocks and springs are new in the rear. any ideas?
shundal
NorCal
Check your rear sway bar links and bushings. They could be too tight or need greasing. Had that happen to mine before
Rangel
Rangel
Ill check, thanks happen to know if the bushings are the same size as the front? I have an extra set from when I redid the front end.
shundal
NorCal
I don't think so because the front sway bar is thicker than the rear.
Rangel
Rangel
thats what I thought. Im at work, so I cant just go look. Ill change them and see if that helps. thanks
Marcasket
