Squeaks Over Bumps
Z71Tahoe2004
Colorado
I've got a 2004 Tahoe Z71.
Bilstein shocks in front.
MOOG suspension components (heavy duty) in the front, to include sway bar bushings, upper and lower control arms, tie rods, and sway bar end links.
Problem: I'm getting a squeaking sound from what sounds like the driver's side front end (maybe the passenger side, too) whenever I drive over any bumps or uneven roads.
I'm about to go underneath an lubricate the ball joints and apply silicone to the bushings.
Wondering if anyone has any additional suggestions before I get started. Anything I might be overlooking?
Thanks!
GMT800 SUV/Trucks
Seen some threads recently where the new sway bar links and bushings have been squeaking. When you installed the new control arms did you tighten them while on the ground or up in the air? Should be done while on the ground.
Z71Tahoe2004
Z71Tahoe2004
Colorado
PNW - thanks for the insight.
I'm pretty sure the new control arms were tightened up in the air. Makes sense about doing it on the ground, because of the weight of the vic affecting the torque, etc and curb height if that matters. I can get behind the tires with the torque wrench and tighten to spec - any other thoughts.
GMT800 SUV/Trucks
Make sure you loosen then before you tighten them. Plus, spray silicone lube on ALL the bushings.
And, as PNW suggested, lube the anti-sway bar, where it goes through the bushings attached to the frame. Its fairly common to see that interface squeak, without some lube.
Z71Tahoe2004
Z71Tahoe2004
Colorado
Thanks, Joseph. I'll definitely hit those. I usually hit them with lithium grease when I have the truck up in the air for an oil change (I've got access to a four point lift). I'll give it the silicone this time.
I've noticed that the squeaking from the suspension parts has only developed since I replaced the bushings with MOOG parts. I know there's a period with new bushings that require pretty routine attention - but these have been on for more than a year and have gotten a lube treatment a couple of times. Maybe they need it for a while longer.
Thanks!
Z71Tahoe2004
Z71Tahoe2004
Colorado
Ron - MOOG sway bar end links are polyurethane. Sway bar bushings were rubber. Come to think of it, I think I pulled the MOOG sway bar bushings and replaced them with new AC Delcos, as they were only one size. MOOG sway bar bushings came in two sizes and wasn't sure I had the right one - so I defaulted to OE.
GMT800 SUV/Trucks
The poly bushings are harder and therefore mat squeak more/longer than regular rubber.
Z71Tahoe2004
Z71Tahoe2004
Colorado
Good tip. I'll blast them with silicone and see what happens. If it goes away, I've found the culprits. If the squeak comes back, I'm pulling them and putting the rubber ones in. Thanks Ron!
Tssonebay
