stalling at idle?
E
ebxgsxr
Baltimore, MD
i hope not. it really just started to happen. i should be able to get the throttle body cleaned by this weekend, so if it continues.....i'll look into other possibilities.
DCT
I had a similar problem. Cleaned the throttle body and problem is gone. You do not have to completely remove the intake tube. Just disconnect it at he hose clamp and clean inside with a rag. I had a lot of build up around the edges of the butterfly. Make to open the butterfly and wipe clean all around it.
You can check your alternator output with a multimeter.
E
ebxgsxr
Baltimore, MD
well, just to update......i had a fuel system service done where they clean the throttle body as part of the service. everything appears to be running great now. thanks all for the input.
BrancoRST
