Stalling when breaking :/
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yes some codes do not set off a light but it sounds like your should If it is a engine sensor failing. if the ignition coil is flaking out or say a loose wire on the injectors that will not show. does your light come on at key on and goes out after start? if not the bulb may be bad or the computer is faulty assuming no wiring faults.
joeshark
joeshark
Yes it does come on during the engine start phase, so it's working. I was wondering if it could be electrical i.e. Spark, ignition coil? Was thinking of replacing the coil, cap & rotor anyhow.
Sent from my SM-N920T using Tapatalk
joeshark
joeshark
Thanks sunlit; unfortunately I don't have meter & even if did wouldn't know how to use :/
Would it be wise to upgrade to aftermarket coil such as Jegs & cap/rotor/wires?
Or just go with a autozone duralast replacement?
joeshark
joeshark
So I think I've figured this out. Seems to me & I'm not 100% sure yet. That the stalling only happens when I'm down towards the bottom of the tank. When I fill gas tank to full the needle in dash goes a good clip over the full mark. So i'm wondering if there is actually less gas than the needle shows when I'm below 1/4 tank?
ZeroHour
