starting problems
gpracer1
Phoenix
I have remote start on my truck an its been on there since 2010 an its been starting on a dime now it just keeps turning over an will not start i have to physically go out to the truck an keep turning the key off an on then it finally starts after about six tries then no problems the rest of the day but the next morning the same thing will not start please help my baby is sick an Daddy dont know what wrong?
So you are saying it cranks every time, alarm or with key but takes forever to start?
If that's the case it may be fuel pressure bleeding down overnight. Does your security light on the dash come on?
Yukon&Tahoe
Could it be the "fuel preasure regulator"?
Or - have you tried turning your alarm and auto start off and starting manually the 1st time of the day?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
bleed down over night is normal a "properly" working pump can build up pressure in just a couple of seconds.
---------- Post added at 01:31 PM ---------- Previous post was at 01:31 PM ----------
and what is it?
poppa3577
poppa3577
ok im going to replace the regulator an the gas filter an let you know
SunlitComet
OBS Jedi-Do Good
if you are replacing the regulator just upgrade the whole injector assembly if old design. however before you do that have the pressure tested first.
HDRock1
Flint,Mi
Remote alarm/starter systems typically shut down starter.
Do you have auxiliary tank ?
Rent a tool ,fuel press tester
poppa3577
poppa3577
ok i gave the truck a full service today spark plugs,wires,air filter,distributor,rotor,pcv valve, gas filter now i will see what happens tomorrow
a-reem
