steering pump resevoir...help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Yes a pinhole leak will piss over everything and I can tell you right now if you do not wash down the whole compartment after repairing that pissed PS fluid will ruin a lot of rubber parts among others things real fast.
BCM
Oklahoma City, OK
I'm in the middle of replacing this, got the old one off without a problem, but putting the new one on, I cannot get the nut to screw into the hole on the reservoir, feels like the threads catch then it just turns freely again. I also tried to put the old one back on and have the same problem. Any suggestions?
WiCK3D_SiX
Mount Joy, PA
Keep trying, Move the fitting around a bit as you push and try to thread it in. Its a pain. make sure the o-rings are on the pump side of the line.
BCM
Oklahoma City, OK
Ok I finally got it, now on the top side, I have no problem getting it started but when it's about halfway in it just stops, can't turn it anymore.
dylansmashed
