Steering wheel locks when driving
God
My steering wheel locks when put into drive or reverse when the car is turned on. It will lock up during the first couple times I try to steer it after the initial start, and the only way I've found to correct the problem since I'm driving is to slightly turn the key up, not quite cranking it but slightly up and it will unlock it. It hasn't been much of an issue until tonight when I turned onto a busy road and the steering wheel locked up on me.
It's the same kind of lock you get when you turn the car off. After it unlocks, I can sort of feel the steering wheel wanting to catch onto whatever locking mechanism is in there, and it's not until a couple minutes of driving that that goes away.
Any easy fixes for this?
G
God
What good will that do?
livingez_123
Sandy, OR
Well, when your driving down the road and it locks up, just pray that you don't drive off a cliff and kill yourself.....But then you are God, so what do you have to worry about.
Gzes
the drifting 2dr
Wichita tx
Imo I'd just open it up and remove the pin on mine if I use my finger I can bypass it lol its not really theft proof..
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You need to replace the locking system parts immediately before you have an accident or scare someone into one. Until then do not drive it.
G
God
i think ill go with just removing the locking pin since that sounds easier. Whos gonna steal a 97 yukon with 166k right?
How do I remove this pin?
Gzes
the drifting 2dr
Wichita tx
Break it;) gotta tear it down and see where its connected
