Random steering wheel locking
B
bigskinney
I could not get truck to dealership cause it locked up again and so far I have been unable to make it let go. Call Morgan & Morgan? New steering assembly is about 350.00. If I replace it does anyone know if the new assembly will require any programming?
Not sure if this will help:
I bought a new 1999 Corvette coupe. It had the new electronic steering column lock feature.
Soon after purchase, while driving in a rural area of Kentucky and stopping, the steering column locked and would not unlock when starting the car.
I had to have the vehicle flat-bed towed to a dealer and my trip was ruined. The column lock assembly was replaced after several days, and I continued.
Later, GM issued several safety recalls for the steering column lock on the C5 Corvette models. The recall involved the dealer disconnecting the feature, so the column lock no longer worked (but the customer paid for the feature in the new car price....).
I did a lot of reading online about the issue. Many Corvette owners posted that when their car battery became weak or marginal, the steering column lock feature would not unlock. Many stored their vehicles overwinter, and some did not use a battery tender.
A long story - but is there a chance the battery on the truck is marginal or weak? Is it the original battery?
A weak battery MAY prevent the column lock from unlocking on your daughter’s truck?
I have been driving and working on cars for more than 50 years. I have often seen people say their battery “has to be good” as it is only *** years old - but it is the cause of their problem.
A weak or marginal battery can car all sorts of vehicle problems. Perhaps your daughter can replace the battery if original, or is a cheap replacement one?
Stbentoak
Good advice above^.. Vehicle is beginning to be in the range of a new battery... Have it load tested with a digital load tester. You may be surprised.
When anything is wonky/unexplainable... battery is the 1st thing to check.
NELLY1947
2021 Yukon Denali 6.2 premium pkg. steering randomly refuses to unlock. Motor will start, transmission works, no binding in steering linkage . no error code ( I have code reader) disconnecting battery doesn’t help. The first time it happened I kept starting and stopping engine and opening door so that solenoid would engage and disengage. It finally , reluctantly, partially disengaged ( I could still feel the tip of solenoid rubbing against locking plate. After a few more starting and stopping that rubbing went away and everything seemed normal. Two days later it did it again. I removed steering wheel trying to find locking plate (like on older models) but discovered that it had been re-engineered. Since it had locked up in mall parking lot I reassembled it so I could get it on a rollback but lo an behold it had unlocked itself. I cannot discern which fuses control that module or even if it would run if I could find the correct ones. Is there any way to disable it . I enjoy some of the new electronics but really miss the days when I could fix Anything that broke.
Maybe. if you are parked on a hill and turn your wheel really hard then turn off the ignition. Sometimes it will lockbon the last pin/notch. from there it can be a bit$& to get it out of that spot
