Steering wheel problem
hamd1719
Everytime I drive the Car under 60 km/h the steering wheel turn slightly towards right and when above 60km/h it turns slightly toward left.
Even when making a turn under 60 km/h the steering doesn't come back straight it's always a little toward the right. Same case above 60km/h it doesn't come back straight it stays a little left.
What's wrong ?
Sent from my SM-N920C using Tapatalk
Blueinterceptor
Which way does the road pitch? I had a similar problem. Except mine pitched left. I was told that they don't set it truly straight and that the transport can affect the steering. They will wait a bit to align it to give the vehicles suspension a chance to settle in.
I used the bow tie on the steering column to establish level. Taped from the top of the bow tie to the steering column, used a level to insure straight. Then I used a razor to cut the tape between the top of the steering wheel and steering column. I had them set alignment to my level steering column. No complaints since.
H
hamd1719
I'll get the alignment done soon will keep updating
The steering turns toward right under 60kmh or when making turn it doest come back at 12oclock it stays at 12:02 I need to bring it back to 12. Same happens above 60kmh same thing happens towards left. I'll get it aligned I hope that fixes it, I have 15000 miles on it 2015 Yukon purchased it in Jan 2015.
H
hamd1719
This is the report from the tire shop
He said that there's no alignment for the rear everyone on the forum told me to get a 4 wheels alignment I have 4*2
jackdforme
Yeah I had the dealer align my truck and still I have a pull to the left if the wheel is centered.
Sent from my SM-G935V using Tapatalk
burban2020
