Still bottoms out on 2/3 drop with 2" spacers...
Blazed
Accepting Donations
Free travel would probably solve it but I did the rear hardware kit and it puts the rear axle back into stock position and I've only bottomed out three times in two weeks.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you can make the bumpstop a little longer if you wanted if not cutting off the bracket will do it.
Goodinblack
I Like Tacos
Dirty South
I for one cringe at the free travel mod.
I would do Airlift 1000's if I were you.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
And why is that? Never one issue in over 12 years of doing the mod and you dont cut into the frame.
L
lynxnova
New Jersey
So, which is the safer easiest way to go? And would it aol e my problem?..... Thanks guys....
Sent from my ADR6425LVW using Tapatalk 2
---------- Post added at 11:33 AM ---------- Previous post was at 11:32 AM ----------
Solve my problem?
Modded
That Guy
btw check this out works like a charm if you cut it off.
http://www.tahoeyukonforum.com/forum/showthread.php?t=47016
I have those in black and they work a charm.
I did trim my down a little though. I think I cut off either the first two (or 3) steps on them.
---------- Post added at 12:48 PM ---------- Previous post was at 12:46 PM ----------
The best bet for you is to just go ahead and do the free travel mod with the bumpstop linked above.
L
lynxnova
New Jersey
Hey tony, what's the diference between the travel mod and the airlift?.... Which would u recommed ? And how much do they cost with the bumbstops?
Blazed
Accepting Donations
He's gonna recommend free travel and that would also be easier and less hassle.
They are completely different tho.
Tahoe4neutrals
