stock tape deck above cd storage compartment
ActSwedish
Stockholm/Sweden
"puckhead" I dont know if my car had the c-deck or the cd player down there but def one of them since there is a gaping hole and original wirring harness in there. There was no stereo in the car when i looked at it the first time so I told the dealer to fix a cd player pref original. When the car was deliverd they had put in a Delco original with the cd player on the headunit and it works as it should with dimming and such and sound.
What im trying to say is there has def been something there in my car but not now and the stereo work as it should :)
Regards
NOPROBROBB
NOPROBROBB
UTAH
Any of you guys have trouble with the rest of your system working when you pull the tape deck out? I unhooked mine and the sound doesn't work now.
Ill let you know as soon as i get mine out
Beason
LA
For $26 go to your local Chevy Dealer and ask for the storage unit used in that spot. Take 5 minutes to install.
NOPROBROBB
NOPROBROBB
UTAH
Thats what i finally ended up getting, they ordered the wrong one the first time around but i got the right one yesterday and you re right took about 5 minutes to install. Do you know what the part number is for the rear, i asked the parts guy and he said there wasnt one but i ve been told there is
T-Giv
Colorado Springs, CO
Hey guys I have an '05 Escalade ESV and my brother has my old '02 Suburban. The clown spilled his drink and it ran into the tape deck. LMAO so now it doesn't work. I am going to take the deck out to examine if it can possibly be cleaned/repaired. I'm not sure how the console works as far as getting the deck out. I know it's different than my truck. What's the procedure?
NOPROBROBB
NOPROBROBB
UTAH
Its quick to take out, there are two screws to remove that are located in the cd storage compartment, after you take these two screws out the plastic cover will come off, be fairly gentle, there are two plastic tabs that keep it in place, i broke one of these when taking mine out(the good news is that when i put it back it stays put just fine still). Once you get there there are two tabs on the tape deck that you depress and the tape deck slides right out.
If you need more info on it or have questions dont hesitate asking.
If you cant get it cleaned or fixed let me know, you can have the one i pulled out for 15.00 plus shipping.
T-Giv
Okay sweet thank you I will let you know what happens upon further investigation. Also, I should have consulted you guys first but I figured it would be similar to my truck so I just tried to "pop" the piece out like mine do and I cracked one of the sides. Where would the best place be to get a replacement?
FERGHOE
Hoe Owner
Grapevine
This is mine (got the idea from JKMOTORSPORTS)
It is painted dash color now but these are the only pics I have.
NOPROBROBB
NOPROBROBB
UTAH
Well, if its a big enough crack that its going to bug him i would first try a junk yard to see if you can get lucky, there are two in my area where i live and sometimes they ll have things i need, f not i think your only other option will be going through a gm dealer to get that part ordered.
Dwight5
Do you still have the tape deck? Mine is kaput an would like to replace it.
OptimalZ06
