Stock Turn Signal Help PLEASE.
Sthunter987
I just bought my first Tahoe (1997). Love it. I bought it used so I now have to fix any problems. I have decided to join this site for all the helpful information, but now I need your help.
I noticed the right front (pass side) stock turn signal was out. I replaced the bulb with a standard 3057. I also noticed the corner marker light was out. when I replaced the bulb I can not get the bulb to light up (I will replace that bulb again this morning).
Now here's the problem: With the head lights off. My pass side turn signal will works but it makes my dash lights "blink" at the same rate. It also makes the drivers side "blink". The drivers side works perfect.
With heads lights on I have NO turn signal on the pass side at all. Drivers side is still perfect.
I have replaced the following:
Turn/hazard box.
All bulbs on the pass side.
Checked all fuses
I all did was replace two bulbs (I also tried to re-install the orginal bulbs but that did not work) and have now enter this nightmare. Can anyone help?
Thanks.
S
Sthunter987
Turn Signal Fixed
UPDATE: I'm posting this for anyone that may run into the same problem. As I stated earlier I bought this SUV USED.
The previous owner had placed the wrong bulbs in the front turn signal. I went the Auto Parts store and bought the bulbs as stated in the owners manual (2357A) and replaced in the parking lot. PROBLEM FIXED.
Venator
