Streaming Bluetooth Audio in a 2011?
Tim H
Hey All, new here..
I have a 2011 Yukon.. bluetooth works fine for phone calls. I know via the manual it does not support audio streaming via bluetooth.
My question.. are there any aftermarket devices I can add/use to stream audio using the stock head unit? I'd like not not add another bluetooth device because I can only pair to one of them at a time and switching to pair with the other device when a call comes in would be a pain.
Appreciate any help.
T
Tim H
What do I need to buy to keep my steering wheel controls?
t.stimpson
i have the blue fusion by scosche. It works well for streaming audio/music from my phone.
KahneFan
If you have an AUX in the Kinivo BTC450 is very easy to add on for BT streaming. It also gives you hands free, if you don't have it already.
dak244
...and the factory mic would be good too..
Just to cofnirm, if you put in the 4100 or similar, you can't retain the factory mic right (given the BT system is integrated through OnStar)? You have to use the mic that came with it?
janabanana
