Stuck in 4WD
wsteele
Fless and Fuvar0715 thank you for your replies. Fless are you saying the issue is in the encoder motor assembly? I am confused with the order of operation so I am getting hung up on if the issue is with the encoder motor, the transfer case control module, or the selector switch. If you’re feeling is that it’s the motor assembly then I will go with your educated guess and I appreciate you sharing the knowledge. Fubar0715 I am located in just west of Boston. Not sure how to add that into my profile but I will look into it. Thanks again for all of the info and if anyone else has anything to add, please post. Thanks again.
You don’t have enough information to make a definitive judgement on which of the three candidate components (wiring, TC motor, TCCM) might be the culprit. If the wiring is OK, then the GM engineers who wrote the shop manual think the TC motor is next most likely.
If you want to be sure which component will fix the problem, you need to follow the diagnostics outlined above.
Most of the harness likely is not the problem, but the short leg that goes to the motor itself is under the chassis and routed pretty close to the FW drive shaft, so might could get chafed/cut.
The next candidate in the test protocol is in your the TC Motor. If neither the wiring or the TC Motor are bad, then the book says it is the TCCM.
As Fless pointed out, you can do the test steps above to get an exact determination, shotgun parts replacement or take it to a competent shop that does a lot of GM LT work and they will get it fixed in a few hours or less.
I think if there are no obvious issues with the portion of the harness going to the motor, a shotgun approach of first installing a replacement TC Motor and if that doesn’t fix it replace the TCCM, probably would yield a successful result. The problem with that approach is you don’t have a scan tool that can do the motor relearn (which might not be a big deal if you get the motor and TC in synch and the state the TCCM thinks things are in, are compatible).
If you buy a new TC motor and TCCM, again, you may need the motor relearn and it would be really nice to have the calibrations appropriate for your VIN flashed into your TCCM.
All that points to it being a good idea to take it to a qualified shop, or maybe using the extra money you will pay a shop for their equipment and know how and buy your own Tech 2 and maybe a DMM.
Fless
Super Moderator
Elev 5,280
Agree with @wsteele. A better scanner might indicate the failure type byte which is in addition to the code; that may narrow things down. Without it, though, the diag steps shown first show the test for signals coming from the Transfer Case Control Module (TCCM). The component test specs the required resistance of the actuator (sometimes called the TC encoder motor).
So without testing those items it's difficult to tell which device is causing the issue. If I were you, I'd see if another scanner would narrow it down, or seek additional help. It's most likely that the actuator, as a mechanical device, has worn parts. You could throw a new actuator on the TC ($200) I don't think it requires programming), but be prepared for a TCCM replacement, which may require programming. Some of the older TCCMs are available rebuilt from Dorman that don't require it, but I'm not familiar enough with your year to know. Check RockAuto for parts, or the GM store in Amazon. There could also be a wiring problem, which is what the diag steps would confirm.
Hope that helps. Let us know what you decide to do.
Fless
Super Moderator
Elev 5,280
As a further commment, I guess there is a possibility that the switch is bad, but I don't think the lock circuit code points to that. If you can find one relatively inexpensive, maybe in a junkyard, you might change it out. But, again, I would concentrate my efforts elsewhere, at least initially.
U
UpAndDown
Boston, MA (MetroWest)
wsteele and Fless thanks very much for the replies. I think I am going to throw a TC encoder motor on it in the next week or so and see if that’s it. I know it’s a shot in the dark. Does anyone know for sure if the encoder motor needs a relearn procedure done on it for sure or not as wsteele mentioned? I have read that the TCCM requires it, but if you buy a Dorman unit it does a self calibration. The encoder motor however, I have not read about a procedure being needed. If it is needed, will this render the truck undrivable until it is completed? Any and all replies are welcomed and appreciated. Thanks again for all of the help.
wsteele
The shop manual calls out a relearn procedure with the scan tool when the motor or tccm is replaced.
I have read service articles that state if you put the TC in neutral before the exchange, it will be synchronized as the new motor will come in Neutral, hence neither device will be out of synch (there is no intelligence in the motor itself). I have read other stuff that says you can just manually turn the TC selector to neutral with a pair of vice grips after removing the old motor and they will be ready to go, but if it were me, I would be concerned the TCCM would think it was in the last position it knew and be out of synch with where the motor and TC were positioned after assembly.
If I couldn’t be sure I got the TC to the neutral position electronically (that is the TCCM thought it was in neutral), at a minimum I would leave the battery disconnected overnight before hooking it up and trying to fire things up. Definitely unhook the battery before starting the replacement of the motor.
wsteele
Sitting here with a cup of coffee and my other MY specific repair book (not factory shop manual), there is no mention of the relearn procedure. They just say to manually set the shift position to neutral after removing the old motor so the new motor is aligned with the shift shaft. After install, it is implied the TCCM will read the position from the encoder ring that it is in neutral and that is what will be indicated on the switch.
Inthink if I could get it to go into neutral electronically, I would do that before jacking the truck up, but if it won’t change to neutral from 4WH, I wouldn’t worry about it, I would just put it in neutral manually underneath.
Fless
Super Moderator
Elev 5,280
@swathdiver it's a personal choice to bypass the diag. Not necessarily recommended but it happens all the time. You can lead a horse to water....
@UpAndDown When you're ready to start the work, look at your owner's manual for the specific procedure to put the transfer case into neutral, and at least try that before disconnecting the battery. Be sure to chock a wheel both in front and back of it, since the tranny parking pawl won't have any effect on keeping the truck from rolling.
rsetareh
