Suspension Suggestions Please
1992rs
OR
I ditched my autoride and like everyone else put in bilstein 4600's. I left the factory spring in place because I want to lower it sometime and just cant find the justification to buy another set of factory height springs. I installed Hellwig sways at the same time and it rides nice and controlled.
05Single
afraid of the dark
YeaH, I haTE wHEn peopLE dO ThaT cRAp! :893karatesmiley-thu
I don't mind when other people do it, just pisses me off when my phone does it and I wanna throw it into the nearest lake.:flame: I hate samsung with a passion!
ratedr120
ratedr120
NYC
I Was Told The Factory Springs Are Softer So I'll Probably Get Firmer Ones. I Installed Eibach Swaybars In The Front And Rear
ratedr120
ratedr120
NYC
I'd recommend the 4600's as well. Make sure that the jounce stops in the front are in good shape. Actually just replace them, they likely are worn out.
Also in the rear you will want to replace the springs, as the springs are likely worn for one, and additionally are much softer in the airride equipped vehicles since the air shock helps support the vehicle. 81071 is the standard height/duty spring. 81069 is the HD/z71 spring that will leave you with a higher rear ride height 1-2"
Here are the two options:
MOOG Part # 81071 Constant Rate Spring
Bar Size (In): 0.640 Inch
Free Height (In): 16.042 Inch
Install Height (In): 5.266 Inch
MOOG Part # 81069 Constant Rate Spring
Free Height (In): 17.177 Inch
Can You Send Me A Link For The LED Fog Lights That You Have If You Brought Them Offline Please. Much Appreciated
Mike4400
