Swapping headlight bulbs…HOW THE..?
CMoore711
@Chickensandwich So your passenger side is difficult because the PPV runs a dual battery set up and it’s located right behind the drivers side headlight? Right?
Wouldn’t unhooking the battery and removing it be easier than taking off the whole front bumper?
Chickensandwich
Chickensandwich
No, the passenger side was fine, it’s the drivers side. The battery was removed and there is still no way to reach the high beam or blinker.
Chickensandwich
Chickensandwich
Aftermarket bumper removal, two blinkers and one high beam headlight replaced, $480 please. I made sure they topped off the blinker fluid and LED oil while they were in there…it’s the least they could do.
marcello1395
It is a pain, but it is doable without removing the bumper. Small hands also help a lot with this job. I was able to swap both of mine out in maybe an hour or two when I did it.
Chickensandwich
Chickensandwich
The passenger side was fine, the drivers side, no way to reach the blinker. The bumper had to be removed because one of the blinker bulbs popped out in to the housing. The only way to get it was to remove the housing, thus removing the 190 pound after market bumper, thus, $480 please
CrashTestDummy
Pearland, Texas
Yeah, the manufacturers are doing their best to make you come to THEM for the simplest things now, like replacing a headlight bulb. We're holding off on the LED upgrades on our '18 until after my shoulder joint is replaced. It's just to painful to pull all those bolts at this point in time. Sure my bride is great at this sort of work, but there's just a lot of disincentive to do that at this time.
Chickensandwich
Chickensandwich
The lights are nice and bright. The OEM lights were yellowish compared to these. In the future, I’d do just the low beam. I rarely use high beam, so lesson learned
With my '07, I remove the entire headlight cluster, and then I change the lights. There are a couple of connector screws on top, and there is 1 connector screw that is located in the wheel well, behind the shroud.
CrashTestDummy
Pearland, Texas
We put LED on our 2010, and our 2012 9C1, so I know how nice they are. the caprice required just a little hand gymnastics to get into and out of the headlight module. The 2010 required removal of the headlight module to get to the high beam, and then, required a certain type of bulb (one without the fan on the back) to fit.
I'll be putting LEDs on the 2018, but need to wait until I get some quality time in the shop to pull the front end off the truck to get to the light modules.
Chickensandwich
Chickensandwich
Exactly…you can’t get to the blinker on the drivers side at all unless you pull the housing out. I have all LEDs in there now so hopefully I’ll never have to go through thst again. If a light burns out, I’m selling the truck
TuffyMuMu
