Sway Bar End Link Click Noise
YukonCrazy
Raleigh, NC
I suspect the sway bar end links are what is making a *click* noise when initially starting to backup. Do these look right and how much are you supposed to tighten them?
08grey
Yes tighten them more. You want to squish the bushing some.
fiatdale
Houstons Best
Houston
Yeah, that looks snug, not tight. That upper bushing isnt compressed at all.
YukonCrazy
YukonCrazy
Raleigh, NC
Well, I did tighten them down some more, but I still get that small *click* when backing up while turning. Maybe still not tight enough?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Is the hole elongated on a arm?
OR VietVet
Multnomah Falls
Military
Willamette Valley
You may be hearing the brake pad release when you let off the brake pedal and start to back up. At first you just said back up and then you said back up and start to turn, which is it? Makes a difference. If you have a loose hub bearing that can flex as you start to turn and again can hear brake pad movement/click. What do the sway bar frame bushings look like? The second pics of end links look better with the squished bushing. Key is knowing if straight back up or back up turning.
YukonCrazy
YukonCrazy
Raleigh, NC
Sorry. It makes a single click noise when I start to backup with the wheel turned.
kirkdc
