Switching from hydraboost to STD brake booster
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Change power steering lines to a non-hydraboost, need vacuum source for brake booster,.
Not hard really.
reedal
Virginia Beach, VA
What about the DC quad bracket? How do they make theirs fit without removing hydroboost? You fabbed your own right? I can't remember from your build log. If you were able to make adjustments that matched their bracket, then that could work for you.
Daviddto
Daviddto
Houston
I used the JZ designs Alt bracket. I know for sure that I would need to mod the brake fluid reservoir. I will look into the DC to see , I never thought about that
reedal
Virginia Beach, VA
:cheers: Glad to see you got your wall giving you what you wanted finally. Definitely a major improvement from before
massivespl
I'm not mean, I'm honest.
Michigan
Yea I have DC quad alt bracket and it says you don't need to move anything to install it. Should be putting it on my truck this summer.
Daviddto
Daviddto
Houston
Not hard really.
I guess it's like anything else, just need to research it, figure it out and do it. I would like to avoid making the switch.
Daviddto
Daviddto
Houston
It's a pricey bracket but worth it if I don't have to switch to vacuum assist. I am going to e mail them tomorrow
Roblusk
