T case swap
Fishin757
VA Beach
does anyone know how hard/what would be involved in swapping a NP246 Tcase for the NP241? as far as i know the 241 is a manual selection (that i dont have). i want to do this because from what i have heard i need a non-slip yolk case to do a SAS. on top of knowing the 246 has problems with the pump inside creating a hole (that i suspect is starting on mine). kep in mind i do plan on doing this my self in a driveway. shouldnt be too hard right?
---------- Post added at 04:14 PM ---------- Previous post was at 04:09 PM ----------
oops.. forgot there is a engine/drivetrain section :hands:
mods feel free to move
Fishin757
Fishin757
VA Beach
:jawdrop: your kidding....... So what all I can do is upgrade/repair the one I got and get a slip yolk eliminator?
---------- Post added at 11:31 PM ---------- Previous post was at 11:16 PM ----------
A guy on fullsizechevy has a full write up on his. Straight forward untill you get to wiring :/
SunlitComet
OBS Jedi-Do Good
unknown at this time.
rebuild it. don't know what to do about an eliminator but i am sure something is out there. adding a 246 to a vehicle not equipped with it is a integration nightmare.
purple 'hoe
Green Bay, Wisconsin
Are you talking about swapping in a NP241? In replacement of your NP246
Or the other way around, swapping in a NP246? I'm confused right now
Fishin757
Fishin757
VA Beach
No I think sunlit has it backwards. I have a 246 and I want to put in a 241
SunlitComet
OBS Jedi-Do Good
gotcha. not as hard but still need to make a good amount of changes and reprogramming.
---------- Post added at 09:32 AM ---------- Previous post was at 09:28 AM ----------
tcase, drive shafts, wiring and a bit more.
Fishin757
Fishin757
VA Beach
yeah. the wiring is what seems to mess people up. i think the back shaft will still work because the 241 has a slip yolk in the back still. though i would change that too at some point but thats besides the point. but me and wires dont always get along
electro
Kitchener, ON, CAN
There's a product for your the pump issue. It just slips in after you open up the case and will protect against the pump knocking against the case. It's basically a glorified washer. It's easy to put in.
You have an electronic transfer case now, right? That's more convenient that a manual isn't it?
hosleyb
