Tahoe 2006 rear w/wiper doesn't run
CHARLIE QUICK
Rear wwiper stopped running...have checked fuse, run second ground as suggested in forum, and still nothing ....
No play in wiper ...
Washer runs fine ....
Can motor be disassembled and cleaned ??
Any suggestions ??
Izcain
I know you said you checked the fuse but have you tested for power at the motor?
possible break between the fuse and the motor? or the motor could be done for.
phil816
Mine stopped running as well, Pretty sure its the motor. To my knowledge there's nothing to clean or fix you just replace. Local stores here want about $150
Multnomah Falls
Use a 12 volt test light and check for the power and you can even use a jumper wire to supply power but I bet the motor is bad. Didn't check for power at motor right after checking fuse?
Pacdad
