Tahoe BIG Brake Kit
305Tahoe
Hey guys looking for some Help or input, been searching and cant come up with much ...
Looking to Swap out my front brake Set Up for something Bigger..
Cant really find what our trucks (96 tahoe 4wd) Spindles are interchangable with...????
I was thinking along the lines of the Spindles set up off the Newer Hd Models (2000 up) . Regarding Calipers the same or if not Z06 (97-04). I aware of having to fab up some Brackets but it aint Brain Surgery .....
Any Input would Help , as Starting from Scratch!!!
p.s.
reason for swapping out spindles is as I dont SEE any Big Brake Kits for it...
riviera rider
ya good luck trying to swap spindles i wanted to do that to make my tahoe 8 lug for my rims and couldnt find shit that would work id just find an after market big brake kit but be ready to spend like 2g's
305Tahoe
haks310... thanks I will look it up
Im tryin to go the route of OEM parts to keep cost down , but Ill look at the site , as im sure there is Usefull Knowledge!!
haks310
Got LEDs?
SoCal
SSBC kit will be A126-19...looking at $700
Baer has two kits, one is $2700 and the other one $3800+
305Tahoe
Thanks haks..
they are pricey ..!!!!
. Illl figure something out.. Ill mix and match and Ill come up with something..Ill stick to Original parts , as they come fairly cheap to ... Im a Used Auto Parts Dealer so I just have to take some time to go through the Trucks I can use...
THanks for the Help ...
emfadz
