I would like a little lift to my Tahoe so that sounds perfect! I will check with my mechanic and price all of it out! Thank you!!!
I’d vote towards fox or king shocks if you got the money get the DSC adjustable ones and you can fine tune them for how you want it to ride (firm/soft)
The coil overs are super easy to swap out and so are the control arms but you would have to get it back good enough to drive it for a alignment afterwards…
I’ve had 2 sets of fabtech an arms and the one set is 4 years old with 0 issues out the joint or the bushings not even a squeak. They got a couple bad reviews on Amazon but I believe it was from installation error one guy broke the bolt and it diddnt look like he drilled his spindle out to fix the tapered pin on the uniball so it snapped at the threads.
![IMG_3389.png IMG_3389.png](https://www.tahoeyukonforum.com/data/attachments/426/426601-3149091e112ef471f73da1bc7460da44.jpg)
Here’s the part number for the control arms they are the best deal I could find for uniball arms most run 750-900$ sometimes you can find them on sale on Amazon for 500$ or so
![IMG_7460.png IMG_7460.png](https://www.tahoeyukonforum.com/data/attachments/426/426602-7cd2dd7c6d97c9301f1eec70d7076fe9.jpg)
These cam plates lock the alighnment in where you cannot knock it out again I’ve beat the hell out of mine and I haven’t had to get an alignment since I put them on.(the stock sliding style cams like to move or come loose over washboard roads and bad bumps)
Note I would recommend cutting the bump stop for the upper control arms so you dont bottom out out with the new arms beings you’ll have more downward wheel travel
![IMG_8310.jpeg IMG_8310.jpeg](https://www.tahoeyukonforum.com/data/attachments/426/426603-58ed71bf9317236f6c57004caf4ce14c.jpg)
Pic of my setup here
