Mrclean81
whats the advantage of wetsanding the paint?
how hard is it to do?
is it easy to screw up
truck looks great now!!
Wetsanding greatly helps in leveling the paint and smoothing out any defects or orange peel. In this case, it was to remove the deep scratches put in it from smashing through God knows what. I also do all the touch ups on rock chips and deep scratches before I sand, that way they are smoothed out and almost invisable when its done. The down side to wetsanding is that if your not careful you can sand too much and go through the paint. Most vehicals these days have a healthy clear coat that makes it alot safer but its still not fool proof. Sharp body lines and the edges of panels always have less paint than the rest of the vehical and these are the spots that you want to stay off of. Plus, everywhere you sand you also have to buff and you always have to keep that in mind. A good rule of thumb is to stay an inch or so away from edges with your paper. This way you dont have to run the buffer all the way up on a sharp corner and risk burning through the paint. Once a person gets the hang of it its not hard to do. It really sounds harder than what it is. Its just time consuming. Heres a link to a differant Border Patrol truck I done that was even worse than this one. I dont want to ***** up the detailing section here with non related vehicals but its a good example of what wetsanding can do
http://www.detailcity.org/forums/detailers-showcase/29341-f250-border-patrol-project.html
