Tahoe shut off while driving??
PG01
Up here to the right
What’s up guys, I’ve been having problems with my tahoe(2015 Ltz) in the last 3 weeks. My main problem is that it’s been shutting off while driving and sometimes the radio and dash goes black. Has anyone experienced this problem or can anyone hear give me an idea on what can I do to fix this ?
Go straight to your battery and make sure both pos and neg are tight, not just finger tight, remove the wires and clean the terminals with a wire brush and then tighten them back up with the correct wrench.
Follow all your ground wires and do the same.
If you still have the problem, they probably got water in the fuse box and it’s starting to corrode inbetween the 2 halves.
daryl
Atlanta, Ga
Different vehicle, but my son has a '16 Colorado that did exactly that. His research revealed the ECM was at fault with others that experienced the same thing.
BG1988
file a NHTSA report
MORE reports they got for a single item the more chance they will recall
bobby88
