Tahoe/Yukon Headlight Information Thread
05Single
afraid of the dark
@05Single Yeah bro I am the same..."ANTI-AMBER"!! Alright I'm going to give it a go and attempt to remove of it!! @Tonyrodz @Thatsquishykid717 @05Single any pointers before I get started? Don't want to melt the lights or ruin them. What's the best product to use to reseal them? Appreciate it guys!!:thumbsup:
Never go above 250 for more than 10 minutes. Lots of videos on YouTube . I use a butter knife and several flat head screwdrivers for prying . Be patient, don’t expect much movement first time around out of the oven. Start on the outside. Use gloves . I use retrorubber . But I’ve used interior/exterior sealant from Home Depot . Black for black and grey for yours because they’re chrome
05Single
afraid of the dark
Also you can push the amber out and just open the corner of the light just enough to slide the amber reflector out then close it back up and put it the over reusing the same sealant. No need to open them all the way up if you’re not gonna do stuff like paint or strips etc
Thatsquishykid717
Annoying guy with the loud stereo
I agree with @05Single he is a little more ballsy than I am though I just always bake my lights at 170° for 7-10 min at a time. I always use morimoto retro rubber. Used the Home Depot stuff before but didn’t have the best luck with it. I did get lucky with a set of corner lights before I was able to get the amber reflector loose, get some small side cutters in the 194 hole, and cut the amber reflector into small enough pieces for it to fall out. Only tried that on one set though but it worked pretty good
Tukkr
The Netherlands
Anyone know a good brand for (black) project headlights for a 2002 Tahoe? There are loads of brands (depo, lumen, ipwc, spyder, anzo etc), but who makes a quality product? I dont mind spending a few $$$. Thank you!
Ambitious02
Southern Cali
Alright guys, I did the DRL delete by replacing the DRL socket with another turn signal socket and used LED switchbacks. My drivers side won't flash with the turn signal, but the passenger side is good. The drivers side will flash with the hazards though....rewired that side in case I had a bad solder joint and still nothing...any ideas?
Ambitious02
Southern Cali
I think the Depot's would be a good choice!!
