Tail light ?
FVC
I am looking to get a set of led tails for my 07 YD, What is the best quality as far as fitment and build quality I just don't want something cheap that wont last or fit like factory. What are you guys using that your really happy with ?
Thanks in advance
Jmat
Southern Cali
A lot of folks here seem fairly pleased with G5 tail lights. Just run a quick search of the forum and you'll find a ton of info on them. Good luck.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
i went with Esky tails. They are more expensive and you have to get your harness modified.
picture.php
KMeloney
The G5s are identical to the Esky tails, apparently. That means that they are also shaped like the Esky appliqués. So, if you want a proper look when adding G5s, you'll want to get Esky appliqués, too.
Otherwise, the G4s are shaped like the factory Tahoe/Yukon appliqués, and so you won't have to change appliqués if you go that route. The G5s and G4s all fit in the tail light space with no modification.
As far as the G4s' quality is concerned, it looks like they're all coming from the same factory, and quality can be hit-or-miss.
Outside of the G5s and G4s, I haven't seen any aftermarket LEDs that I like.
QUYHMK
