Did you look from underneath to see if can get a pic from ground up?
---------- Post added at 03:28 PM ---------- Previous post was at 03:25 PM ----------
Try lmctruck.com out of Lenexa, Ks. They got it all for these rigs.
---------- Post added at 03:36 PM ---------- Previous post was at 03:28 PM ----------
Go to that website and type in the year make and model and use the word "hinge" as a search word. Open up picture #29. You will see item #31-hinge pin for $2.55 each and item #32-bushings for $1.95 each. You need 1 pin and 2 bushings per side. I would do both sides. Call 800-LMC-TRUCK if needed. They will be like the pin and bushings for the door hinges.
