Taking off door handles
WhoDatPanic
WhoDatPanic
ohh so you can basically have no key holes at all on your tahoe if you switch them around?
puckhead
CO
There a good place to buy these handles or would a junk yard be the best bet?
brassknucklemafia
phoenix
LMCtruck.com
smooth or textured depends what you want
page 9 online catalog.
cost 19.95-49.95 depending what you need
i just replaced all 5 handles(previous owner had these retarded chrome covers glued to the stockers, ruined them) anyways it only cost me 163.54 with shipping for all the handles.
hope it helps
puckhead
CO
LMCtruck.com
hope it helps
Thanks you sir! That will help alot
Tahoewhat
Ballin' on a Budget
TX
the handles are identical, the difference I think is the length of the metal rods that connect the door handle hinge with the lock itself.
B
I just tried this, i have one from a rear and took my front out, but the actual handle on the backside is different. Unless its just b/c of the keyhole lock. But i couldnt get it in. The rod was to high and was hitting the outside of the door and wouldnt go in.
Heres a pic of the rear door handle, the metal piece is the piece that im talking about that is different. The front metal piece isnt that far over. And for some reason i cant just swtich them, cant get the pin out.
----- disregard, figured it out, sat back had a drink, then realized just pull the pin out of the rear door handle and then put the front mechanisms on that handle...no now key hole.. duh-----
Alright tried this, no go. I have a rear door handle from a 05 burban. Switched over mech. but handle itself wont go in the holes to bolt it to door. The part where you put the pin through, is holding it from going in the holes for bolts. Anyone done this before.... ?????
tadv
