True Dat!No, because I like boobs better than dudes.
I have a little ac to 12 volt dc supply with a cig lighter socket that works nice.So here is a curious thing. Many if not all of these clones have power supply deficiencies that cause the tool to reset if the vehicle is restarted. To overcome this some, myself included, have separately powered the tech 2 using the port on the tech 2 ifself along with the cigar lighter power cable that comes with the set. I use a wholly separate power source, not the ac adapter but a battery booster jump box with aux power outlet.
But it was fine for years, lolme too but shaggy no like because money over hoe's I guess
yep..... but he's the owner and I kinda like this place except that it's now ingrained with facebook softwareBut it was fine for years, lol
I don't do facebook, but how is this ingrained with it now?yep..... but he's the owner and I kinda like this place except that it's now ingrained with facebook software![]()
xenforo is just using the same open source stuff php, mysql, etc, it's very copy-catishI don't do facebook, but how is this ingrained with it now?
I used to use the power connector on the Tech2 for programming but that connector came loose inside and became unreliable and that’s when I found out about the one on the DLC cable so I’ve been using that one. I never had issues with the one on the TECH2 until it became loose but never read the instructions either so I didn’t know there could be an insufficient ground. Got to know. I was just glad there was another option once the first one became flaky. I had the power wire taped to the Tech2 so it wouldn’t move and lose power in the middle of flashing a module.Do note that there exists a difference between using the ac adapter at the DLC cable end vs using it on the tech 2 itself
