Tech 2
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Does anyone have access to one? :Handshake: After installing my wheels the increased PSI is causing the DIC to prompt a "check tire pressure" message for each tire at each ignition cycle...
Sepiroth
I am here
Kouts, In
I doubt it is due to the larger wheel. What it reads like is that maybe one or more of the pressure sensors arent communicating the correct air pressure.
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
The wheels and tires were shipped to me mounted/balanced, etc. so all I had to do was install them. Thereafter the re-learn of the sensors was successful but now the ECM is prompting the DIC to display the "check tire pressure" message because 45-50 PSI is much to high for a stock tire/wheel application....
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Maybe I am reading this wrong, so the person that shipped them to you had the sensors already installed in them?
CodeB4U
Houston, Tx
I have access to a Tech 2, What sensors did the shipper install? Part #'s? How did you relearn the TPM? Does it give a TP reading? What are they?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I am not sure what sensors they were... but can find out tomorrow if this is necessary.
I followed the Owner's manual re-learn process which was successful. They all give accurate TP readings which is currently ~ 46 PSI cold.
quikag
46psi cold is WAY too high. Lower to 32/33 cold and you should be fine.
DABb
