Terrible swaying
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
few questions
1) did you cut the brackets off the frame
2) on the rear the djm swaybar endlinks i always torque when full weight is on them. NOT up in the air.
3) did you mount the belltech shocks facing up or down?
02chevyhoe
Yes i cut off rear bump stop brackets. Shocks are mounted facing up. And I retightened end link and trailing arms and trailing arm brackets. Sway is all gone now. Thanks guys. Now I have a nasty pop going on up front. Thinkin a ball joint maybe
---------- Post added at 10:16 PM ---------- Previous post was at 10:14 PM ----------
Nothin to do with my problems but I was planning on painting my Tahoe black next summer but your making me have second thoughts whiteout. Damn your Tahoe looks sexy
WHITEOUT
Dont Hate-Appreciate
Phoenix
Thanks bro. I was going to do the same thing a few years back. But we decided to keep her white.
Glad you got it all figured out. The little things!! I had a nasty pop going on before, and thought it was the front as well. Ended up replacing entire front end components. But.. Ended up being rear lower control arms binding up. These rigs can make noises sound like there coming from competely different place then it is. Just saying, could still be ball joint tho
02chevyhoe
Do torsion bars have to go on a certain way. I know for sure that driver side bar is still on the driver side same with passenger and the sides that were inserted into the control arms are still in the control arms. But let's say I had A sticker some sort of mark on the top side of the bar and whenbj reinstalled them the mark was on the bottom or else were. Would the be an issue?
stangcrazy84
