Thanks Max - 2/3 in
E
emay
S. Elgin, IL
No loss in turning radius. I have tough angle to shoot my boat onto my driveway and it requires lock to lock steering to get it done. Was fine with no issues.
I do feel what I can only describe as slight tension at full lock when backing. I'm assuming this is normal as my 03 denali did the same.
tahoe02
what do isolators do ? and if you remove them the truck goes lower ?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
They are little rubber inserts (mats) that go on top and bottom of each of your rear springs. They are there so the spring isn't sitting metal on metal and so they don't make noise hitting eachother...
If you take them out, it will lower the truck maybe 1/4 of an inch
I took mine out and didn't notice any more noise...
SPIS
