The 4 Hi mod for a 2000
kickybanks
ky
4 hi mod on a 2001 tahoe
I just did the mod by adding a ground wire to the yellow wire on the drivers side low light. When I first turned on the lights the low bulb smoked a little is this normal ?
Rick
Langley, B.C.
mine never smoked when i did it. maybe try a higher gauge wire( i used 12g). and i cut the yellow one and did a in line ground. works great. alot brighter when high beaming the guy in the fast lane going slow as dirt
IowaTahoe
Iowa
Ok, SO........How do I get the Fog lights to be on while I have the High's and Low's on at the same time. I use to have a 05 SIlverado and did the Diode trick on that truck and really digged having all 6 lights on when brights were on...would love to have that with my 2002 Tahoe.
Thanks
Anonymous
So does anyone have a circuit diagram for the low beams, high beams, DRLs, and fogs? Are they all on relays and are all relays sinking (provide ground) like the low beams? I want to make a switched harness that when the switch is off, all the lights behave stock. Flip it on and activating the high beams would light all 8 white lights on the front of the truck.
bobbywdatool
