The Case for the Tech-2
St. Louis
I've tried using different years and it still has connection error when trying to view the HVAC.
Using newest 33.004 software
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
2001 Yukon SLT
it might be worth spending the $20-30 to get the service manual off ebay and see what procedure it uses
Vehicles have different menu options. Mark, if yours doesn't have HVAC recalibration, try building your truck as a different year or call it an Escalade and see what happens.
You're in the right spot, Mark, but the HVAC recal doesn't show up in mine until I pick the 2003 year, then it's like I posted. I'm not sure if the 2003 relearn would work on your M.Y.
In the 2002 M.Y. I thought there were some other selections under HVAC to see in what position the blend door, etc. were. If you can find those you might be able to exercise the heater controls to see if the settings change. [EDIT: I just reread your last bit and you already found the settings indicators but no recal.)
Maybe that's the key? Pre 03, use the old school methods, 03+ use the tool?
So I looked up the procedures at alldatadiy and it shows exactly what I'm seeing. I can test the different parts of the system but the calibration for all the actuators is done by simply removing the power from the syatem, waiting 30 seconds, and reconnecting it.
Quote:
"Programming and Relearning
The HVAC control module will relearn the actuator limits whenever power is disconnected and re-connected to the module.
Use the following steps to perform the calibration update:
  1. Turn OFF the ignition.
  2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
IMPORTANT:
  • The scan tool must be disconnected from the vehicle to properly perform the calibration procedure. If a scan tool is connected before this procedure is completed, then new calibration values will not be stored.
  • Failure to wait 60 seconds will not allow the HVAC control module sufficient time to clear the old calibration values.
  1. Wait 60 seconds .
  2. Install the fuse.
  3. Turn ON the ignition.
  4. Wait 60 seconds before installing a scan tool."
St. Louis
So I've heard that the spare tire has a TPMS sensor valve in it. How do we view this or turn it on? Is it like adding the afterblow feature to the HVAC module, where you have to go into the setup and add the feature?
So my Tech 2 just arrived. Will take it up north next week and study. Also have the Arnott Compressor to install for rear Air shocks.
If someone else is driving for a time, plug it in and have a look around while the truck is running.
Not heard of this before, there are only 4 positions to learn for TPMS on our generation.
St. Louis
Yeah, I guess I remembered wrong. I think what I read about was when running a spare tire that has a tpms in it if anything special needed to be done. I think in that forum it was brought up that it would be nice if you could monitor the spare tire pressure also.
DougAMiller
Colorado
My Tech2 shows an option for the spare on the TPMS menu, and it was active on mine. However, if the spare has a sensor, it is different from the type on the other 4 wheels, as it doesn't have the threaded valve stem. When I read the tire pressures with the Tech2, it shows a pressure for the spare, but it stays at 46psi and never changes. I've checked the pressure in my spare with a tire gauge and it is 34psi, so I'm not sure where the TPMS system is getting that reading from. Also, the Tech2 displays the serial number of each sensor and the spare tire sensor has fewer digits than the others, so that would seem to indicate that there is a sensor, but it is a different type. I've seen no way to make this display on the DIC, but I have the Torque app configured to display the TPMS for all 4 wheels and had the spare on the display for a while, but since it never changed with temperature like the others and didn't agree with my tire gauge I finally removed it from the display.
Also not sure how to learn the spare TPMS sensor, as a fifth wheel isn't allowed with the normal learn procedure and I don't recall seeing a way to learn it with the Tech2. Maybe that's why the serial number is different, so it doesn't have to be learned.
Gotcha12
