M1Gunner
Pull the negative and positive cable from the battery. Hold pos and neg cable together for 10-20 second.
Just because you replace the o2 sensors the truck isn’t going to magic start running like new again. You have a couple options, if in fact the sensors were the issue. One, using a scan tool, reset the fuel trim values. Two, drive the vehicle long enough for the new 02 sensors to bring the long term fuels trims back to normal.
You gotta give it time if you don’t have capabilities of reset the fuel trims yourself. But holding pos and neg cables together for 10-20 seconds will deplete any power saving stored data.
