the heat wont turn off when i turn off the truck
BlueCollarTahoe
any idea how to fix this? had the heat on yesterday i went to turn it off just kept blowing. i figured mahybe a stuck button or something. the buttons to make it hot or cold still work, i felt the temps adjusting and the power of the blower going up and down as i pressed the switch. i park turn off the car and the air is still blowing. i open the hood and i can hear it on. i disconnect the battery it stops, reconnect it starts blowing again without the engine on. any ideas? what fuse can i take out to turn this off until i figure it out?
kwOH
Banned
Wish I could help, but I have no idea, maybe look for an HVAC fuse and pull it, but obviously you wont have heat until you put it back in.
Sasquatch
Orange County N.Y.
I had the same problem in my girlfriends olds aurora, After some research it turned out that the blower motor resistor was bad. At first the fan wouldn`t shut off even with the ignition off so i pulled the fuse. When i plugged it back in for some heat this fall i got nothing. changed the resistor and it fixed it.
Sasquatch
Orange County N.Y.
I found the service bulletin,
A/C - Blower Motor Inoperative or Won't Shut OFF
Bulletin No.: 06-01-39-002C
Date: January 18, 2008
TECHNICAL
Subject:
Blower motor Inoperative or May Not Shut Off in Extremely Low Ambient Temperature Conditions (Replace Blower Motor Control Module)
Models:
2004-2007 Buick Rainier
2003-2006 Cadillac Escalade Models
2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2007 Chevrolet TrailBlazer Models
2007 Chevrolet Silverado (Classic)
2003-2006 GMC Sierra Models Yukon Models
2003-2007 GMC Envoy Models
2007 GMC Sierra (Classic)
2003-2004 Oldsmobile Bravada
2003-2006 HUMMER H2 Models
with Automatic Temperature Control HVAC System (RPO CJ2)
Supercede:
This bulletin is being revised to update the model years that are affected and add the Oldsmobile Bravada. Please discard Corporate Bulletin Number 06-01-39-002B (Section 01 - HVAC).
Condition
Some customers may comment that the blower motor is inoperative or continues to run after the vehicle has been shut off.
Cause
These conditions may be caused by a blower motor control module failure. This failure may occur when the vehicle is operated in ambient temperature conditions of-23°C (-10°F) or below.
Correction
Replace the blower motor control module if the vehicle experienced a blower motor control module failure in extremely cold ambient temperature conditions.
Technicians are to replace the blower motor control module also called the Linear Power Module (LPM) with the P/N listed below.
ya I would check the resistor, pretty easy to do just pull the cover off the passenger side under the glove box area and it's right there next to the slot for cabin air filter if you have one, takes a 7 or 8mm socket usually, the one bolt (under center console) is a little tricky to get to but you should be able to just remove the two easy ones and move it enough a replacement from dorman should be $20-30 online
BlueCollarTahoe
BlueCollarTahoe
anyone know the right parts number?
this is the type of interface i got...seems it depends on the type of control system the truck has for the replacement. 2004 chevy tahoe 5.3 LT
you should be able to go to the dorman website and put in all your info and it will give you the part number, then copy that part number into rockauto, ebay or amazon one of them is going to be cheaper. I sell some resistor kits on ebay but I probably don't have this one
BlueCollarTahoe
BlueCollarTahoe
didnt even know you could do that. helps alot!!! thank you!
BreBoyz
