the oil pressure or temp
texaschevyryder
LAWTON,OKLAHOMA
on the dash u have the gas and the battery and the oil temp or pressure whichever it is mine sits bout half way where should it be sitting or is it in the right place :idiot:
Sepiroth
I am here
Kouts, In
That gauge reads oil pressure.
Middle is good. Thats about 40psi. A typical oil pressure sensor needs to see at least 5psi to keep the engine running.
Drgnblood
F%ck Douchebagistan!
Douchebagistan for now
ok im not trying to take over the thread here...butttttt.... what if your oil pressure gauge shoots up to 60-80 when you give it heavy throttle....is that ok....i know that the oil filter can sustain up to 180psi..
Sepiroth
I am here
Kouts, In
A lot of times the oil pressure gauges read incorrectly, so take them with a grain of salt.
60-80pis IMHO is not bad pressure at all. At higher rpm's you want more pressure and volume.
hapyspaz
Austin
When you first start you engine, the pressure should be higher, around 60 or so, until the oil and engine warms up. Once warmed up, 40 psi is the average pressure.
I get a lot of people asking me what it means when they are on the highway with the cruise control on and the oil pressure is more like 20-30. This is also completely normal. The engine and oil are warmed up and the oil is running thinner.
J-Will
#Merica
SW MO
so i shouldnt freak out about mine? im guessing the gauge is effed up. the second i start the truck it maxes out at 80. and never moves until i shut it off? just got in one day and it started doin that. before it rode at 40 all the time.
blueflamed03
Oklahoma
no, it also depends on outside temp, and weight of oil used. As mentioned, when it warms up, the pressure will drop.
icehead
Cashville TN
My gauge keeps dropping to almost (0) when at idle and the check gauges light come on.
Then when I take off it goes to 40 or 60 and the check gauges light goes off. as long as i'm on the the gas it's fine. Is this messed up?
YUOnDaGround
Central Virginia
Just to put this out there, ANY engine needs only 10psi per thousand RPMS. As in 10psi @ 1000RPMS, 20PSI @ 2000RPMS, and so on. Having said this, if you are seeing 40-50-60 psi at start up...then you are running too thick of an oil. When you take it up to red line around 6K if you are seeing more than 60-70psi you are running too thick of an oil. Your engine needs flow more than pressure.
Burgy
