Vanquish Auto
- Joined
- Apr 7, 2017
- Posts
- 374
- Reaction score
- 90
All HIDs are not created equal, most “HID” systems sold online are not even filled with real Xenon gas, the ballasts have a lot of “cut corners” and claim being “ digital” when in fact could melt the wiring if becoming defective or start shorting out. Some are as expensive as $200 claiming to be “real philips” HIDs. Some of the bulbs are cheaply glued to the bases or simply do not even have the right orientation meaning the bulb might “fit” in the socket but does not have an OEM light beam pattern which is the main cause for “absurdly bright” or too glaring for road use. Too much glare is synonymous of bad light output and scattered light projection. Most sellers do not even sell the right bulbs or systems for the specific vehicle making it the biggest reason for the customer’s dissatisfaction when purchasing headlights.
Our HID systems are truly one of a kind simply because they do not have any of the flaws mentioned above and become the main reasons why our systems are way above any other system on the market today. Our LED system is the newest and most advanced system currently being produced. We do not stock old generations, LED headlights have been progressing extremely fast compared to all of our products. You could literally go to your local shop and end up buying a first generation and/or copy for $200 if you don’t know what you are buying. Within just the past couple of months there have been produced at least 5-10 knockoff copies of our LED kit, they look just like the real thing but they become useless just around the corner.
OVERALL FEATURES & ADVANTAGES OVER ALL OTHER SYSTEMS:
OEM Fit & Light Pattern Distribution
Low Power Consumption
Guaranteed to Fit
Priced per kit
Brand New
No Flickering
No Dashboard Error
Original Product & Design
What is included in the HID System kit:
2 X HID Bulbs
2 X HID Ballasts
What is included in the LED System Kit:
2 X LED BULBS
2 X LED DRIVERS
LED System Specs:
-Our Original Ten Generation LED Kit
-True Philips LUMILEDS ZES 6 Pieces Per Bulb
-12000 LMZ per bulb
-Adjustable Beam
-Integrated Heat Sink
-Materials combined of Copper and Aluminum Alloy
-LED Bulbs produce no heat inside the Lamp
Important Note:
When Selecting your preferred HID System always go with one of our Can Bus option for European vehicles, Mopar ( Chrysler, Jeep, FIAT, Dodge) and newer Hyundai and KIA vehicles.
Our LED Kit can be used on any car as it is Can Bus built in and ready to work on any vehicle. Some vehicles might need an extra LED warning canceller to work properly.
Our LED kit is best when installed on High beams and Fog Lights. We do not recommend that you use them for Projector, Reflector Low beams or High and Low beam positions.
Guaranteed to Fit
Priced per kit
Brand New
No Flickering
No Dashboard Error
2 X HID Bulbs
2 X HID Ballasts
2 X LED BULBS
2 X LED DRIVERS
LED System Specs:
-12000 LMZ per bulb
-Adjustable Beam
Important Note:
