There are just some days I wish I didn't turn wrenches
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
It's never done.... ;)
Exactly. I recently had a chance to buy a 2004 K2500HD crew cab short bed with 117k miles on it. The interior and exterior were perfect. I mean, showroom condition.
The truck needed several leak repairs under it though. It was not worth, to me, the $16k he said he would sell it to me for because his son is the shop owner I help at periodically. It also needed a complete set of tires. I am so used to my Tahoe wheelbase that I just did not see a need to buy the truck "because of a want" instead of "a need". It was to pricey for what it would still need. I offered him $13k and he said no. All good and shook hands.
My girls 1990 K2500 does all that we ask of it for a truck. At 130k miles on the rock solid 5.7 and everything working, it is worth putting some money in it and it has great tires.
I was already going to do the valve stem seals because of the puff of blue smoke at start up. All those 5.7 engines need the seals eventually. The a/c blows cold but the clutch is noisy. I have the special tools for the work, so gonna do it and parts are here. During the inspection of the a/c noise, I found the oil seepage at the front and rear of the intake. So, me being me, I am gonna do it all and she has all paperwork of the truck history since she has owned it before I got my hands on it. The tune parts are only 5k old. The TBI does not have to come off and neither does the egr but they will be removed and new gaskets installed during a clean up. That right rear heater hose connector is a PITA, so it gets done.
The belt and hoses and tensioner and idler are all relatively new, I know because I did them. The thermostat is done just because. Of course add in an oil change.
The truck has absolutely no dents and the paint is decent. That is why it got all new lights, front and rear, new headliner and visor fabric. New side moldings. New grill and BowTie. New fan shroud. It will continue to get taken care of. She loves the truck and calls it "The Beast", affectionately of course. She has a 74k miles 2002 TrailBlazer and loves it but really likes driving that truck. By the way, withing the last 8k miles, the 700R4 transmission had a Wa. stae GM dealer put a GM crate 700R4 in the truck.
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I just installed 2 headlights for my neighbor 2 days ago. On a 1986 Nissan 720 pickup. Rusted/frozen screws on trim ring. had to drill out. Next day he does not have turn signals. hazard flashers work. I swap the flashers and the turn signals work. I told him to get a turn signal flasher, #552, and showed him where to install. Today he called me and said the turn signals still do not work. I asked if he checked with the key in the run position. He said yes. I walked down and the turn signals worked. he did not have the key turned far enough. I then explained that there was absolutely nothing I could have touched or done replacing 2 headlights to stop the turn signals. Even the screw drilling. I did not charge him to diagnose the turn signal problem to begin with. I should have as an "aggravation fee".
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
This morning my next customer should at 8 and he "helped" me put front struts on his, new to the growing family, 2015 Chrysler Town & Country mini van. He was helping me to try and cut the time down and save. It was pretty straight forward and we had two new complete struts and a new upper cowling piece. The old cowling seal, that lays against the bottom of windshield, was cracking badly and missing big chunks. The cowling comes off to gain access to the 3 nuts holding the top strut plate in place. It was all very easy access. The two large spindle to bottom of strut bolts came right out. I scribed the top of each knuckle to mark the spot where the struts tightened. There was one small bolt holding the tab for the ABS sensor wire. Also, one large nut holding stud at top of the front sway bar link. Easy off and easy install. Then reinstall new upper cowling and reinstall both wiper assemblies. Total time was 2 hours and 15 minutes. That includes setting and pulling back out the jack stands and removing and replacing both front tires. He was my gopher. He saved himself about 15 minutes time. Sorry, was a very straight forward job and I sailed thru it with no pics.
tom3
I just installed 2 headlights . I then explained that there was absolutely nothing I could have touched or done replacing 2 headlights to stop the turn signals. ".
But then there's the old "you musta done somethin" to cause it. Change a water pump and the radio quits, etc.
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Right in front of the customers, I will work different switches and components on the dash. I showed this guy, but when I switched the hazard flasher with the t/s flasher and the t/s worked, he had to shut up. Then he went and got a flasher I had called about and set up. He plugged in to the t/s connector, I had already moved the hazard flasher back to it's own connector and showed him. Gotta lead this guy by the hand. He plugs in the new t/s flasher and he did not turn the key on to "RUN". He went to the first click and no t/s flasher, blinkety blink. He calls me and I have to go back down the street and asked if he turned the key far enough and he said "yes" with hesitation. I turned it to RUN and the t/s works. I had also already showed him that the emergency/hazard flasher switch was intermittent. Sometimes just the left side flashed. Sometimes just the right side flashed. Had to forcefully push the switch farther than the detent spot to get them all 4 to flash. I cautioned him to get it fixed. Needs a new switch assembly. I located it for up to $75 and as low as $54. Using my wholesale or military discounts. I told him, one of these days he may need the flashers and if they do not work, the truck could get hit. It is the whole reason for them to work. He is thinking about it. He even asked me if he can replace it. The two halves of the clamshell covers have about 10 screws holding them together. Plus, likely has some things to remove to access the switch assembly to allow remove and replace. I told him I have no knowledge of your abilities. I am thinking about the t/s dilemma when I am saying this.
This is the same 86 Nissan 720 series pickup that I recently did complete rear brakes and wheel cylinders, clutch slave cylinder, valve cover gasket, pcv valve, plugs, front wheel bearings and idler arm.
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
My shop owner friend, here in Junction City, Or., specializes in the Toyota 4.0 engines for timing cover leak repair and timing chain with the VVT set ups. I help when those are in his shop and there is a member at the FJ Cruiser Forum that is coming from Orange County and dropping the truck for work and does not want to travel on roads that use salt for snow/ice clearance. I am up against a wall trying to find definitive info for counties where I-5 travels thru Ca. and Or. Any members that live close or know, please share if you know. Thanks in advance. What you see below is a post at the FJ Cruiser Forum.
Hopefully I can get some help here. I am trying to look up best route for @greengoose to travel from Orange County area to Junction City, Oregon. The problem can be traveling here in February/March and whether there is salt on the roads as you travel up I-5 in the winter time. It is almost impossible to find a list of Ca. counties that use salt on their roads, along I-5, or even a mixture of salt brine and sand or whatever mixture there is that includes salt of some sort. I searched for 45 minutes this morning with no luck. There is a definite list for the Northeastern states but not Ca. and I will be looking here in Oregon. Hopefully there are some members here that can share what they know. thanks in advance. I will also be posting this on 2 other forums I am a member of.
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
In the next few days I will be doing rotors and pads, front and rear, on a 2014 Duramax crew cab. She is metal to metal on the inner pads on the L/F and R/R. All parts ordered at RA. Due in Friday morning and she can drop truck asap.
Then I have oil cooler lines on my landlord's 2018 Suburban.
Then I have a/c clutch assembly, intake gaskets, valve stems seals and new heater hose connector at P/S rear, on my girls 1990 K2500 5.7.
OR VietVet
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Today was one of those days I did not turn wrenches. Got the 2014 2500HD Duramax up on stands and removed all 4 wheels/tires. Custom wheel crap. Anyway, started at the right rear and the caliper slide pins, both of them, would not break loose. 10mm female heads and I had my 3/8 impact and also tried a 3 foot breaker bar and would not budge. I called her and told her the pads and rotors replacement just changed to semi loaded calipers, meaning reman calipers and brackets with new caliper slide pins and hardware and now I can use her pads. Means bleeding the fluid but I am going to just do one caliper/wheel at a time and should be no biggee. I am also doing both intake air temp sensors and doing battery service on the second battery at p/s firewall.
L5Pdenali
