There are just some days I wish I didn't turn wrenches
GMT800 SUV/Trucks
Turns out that this TIPM or better known as fuse block, is a well known weak spot on many MOPAR vehicles over many years. Listed but out of stock at RA and not even listed at Parts Geek. I did find it at MOPAR Parts for $334.48 instead of the normal $497.00. My shop owner friend says he has to replace these on a regular basis and has done about 20 of them in the 1 year the shop has been open. The symptoms match up with some of what she said was going on and that I could not communicate with the code puller. I have pulled codes on this vehicle before when she had a leaking oil cooler assembly and it set a code for low oil pressure.
The first two characters of the initialism "TIPM" do not bode well for vehicle electronics. "Totally Integrated" likely means no repair, just replacement. :mad:
TollKeeper
Brighton, CO
They brought the TIPM to market late MY2004... And it has not worked right since.
I would have thought NHTSA would have gotten involved on it, and made a mandatory recall, since it can affect if the AirBag works, the brakes work, and the Power Steering work...
But it is still in production. One of the reasons I wont buy a Stellantis product.
Edit: It looks like certain TIPM modules have been recalled, you would have to go to NHTSA.gov and see if this VIN is affected by one thou.
GMT800 SUV/Trucks
I am at dentist right now. Will check when I get home.
GMT800 SUV/Trucks
My close friend, shop owner, has been in his new shop 1 year this month. In that time he has seen very similar problems, like on this Cherokee, and each time he has diagnosed as a TIPM problem and fixed them each time. In one year, he has replaced close to a dozen TIPM units. When you look up both options for the 2017 Cherokee, they are out of stock. Out of stock because so many are bad. There is a newer upgraded unit than the 2 shown at RA. Part #68264530AF
89Suburban
Bull in the china shop
SE PA
:popcorn:
GMT430guy
