They stole my truck
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Welcome to the forum from Oregon. As Scott said, it should be in your owner's manual, unless those turds stole that too. :mad:
Nick91l
Bath, Pa
It’s definitely in the manual. I remember to enter the mode, key in ignition, pull high beam switch back. IGN forward, back, forward, back, release high beam switch.
Locks will cycle saying your in program mode. You have a short time to make changes. Then they will cycle again exiting program mode. If you still have questions, I’ll get a pic of my manual they should be the same when I get home (I work nights) good luck!
B
Brian7743
Nick, i downloaded a manuel today. I am about to search it via my phone. If i cant find it, i will look on my computer at work. Thanks for your help.
clandr1
Dallas/Fort Worth, Texas
I found this on another forum, it might be helpful:
Programmable Automatic Door Locks
(If Equipped)
Your vehicle may be equipped with an auto lock/unlock
feature which enables you to program your power door
locks. The following instructions detail how to program
your door locks.
To enter the program mode you need to:
1. Pull back on the the turn signal/multifunction lever
all the way toward you and hold it while you
perform the next step.
2. Beginning with the ignition in OFF, turn your key to
ON. Return it to OFF and turn to ON again. Then
return it to OFF. Once you do this, you will hear the
lock switch lock and unlock.
3. You are now ready to program the automatic door
locks. You will have ten seconds to program once
you release the turn signal/multifunction lever.
The following is a list of the available
programming options:
Press the lock side of the lock switch on the driver’s
side door panel once to turn on the automatic door
lock feature. All doors lock. No doors will unlock.
Do the same twice to turn off the automatic door
lock feature. No doors will lock or unlock. Auto
unlocking will not work if auto locking is turned off.
Press the unlock side of the lock switch on the door
panel once to unlock the driver’s door and lock all
other doors.
Do the same twice to unlock all the doors. All doors
lock and unlock. (This is the factory setting).
Do the same three times to turn off the automatic
door lock feature. No doors will lock or unlock.
You can exit the program mode any time by turning the
ignition to ON.
The automatic lock feature will lock all the doors when the
vehicle speed is greater that 15 mph (24 km/h) for two
seconds. Your vehicle left the factory programmed to have
all the doors unlock once the key is removed from the
ignition and lock when vehicle speed exceeds 15 mph
(24 km/h). See your dealer for more information.
If the lock/unlock switches are not pressed while in the
programming mode, the respective auto lock/unlock
setting will not be modified.
Larwence
