Thinking of buying 94 Tahoe
08HoeCD
Hobby/project vehicle or daily driver?
Me....I wouldn't touch it for a dollar over $1,500
W
weatherfordjacey
Any leaks--oil pan, rear differential, rear main seal?
It looked like the valve covers leaked a little other than that it looked good
Sent from my SAMSUNG-SM-J120AZ using Tapatalk
east302
Mississippi
Not a deal breaker, then. Any idea if the engine or transmission have been rebuilt?
The A/C could be your larger expense. Did they still use R12 in 94 or has it been converted?
Even if you had to replace the steering gear, you could probably do the whole front end for no more than $500 in parts.
Edit: Is it a Chevrolet Blazer? The GMC grill looks like a 90-93, they switched them for 94 to a body colored surround. With that and the hood, wonder if it was wrecked?
Contend997
Frostproof , fl
Sounds about right. Looks like a good deal to me. If you have engine problems you can ls3 swap it or keep it stock but the ls swap is worth the money. Will pay for itself in gas savings in a year. Nice truck I would buy it. The steering is a easy thing to fix the window is easy even If you have to buy parts new it won't cost you alot to get fixed
bigT63
I had a 94 Silverado... I miss that truck... anyway I spent countless $$$$$ trying to get the A/C right. I ended up changing the low/high pressure switch out as a last effort and it worked like a champ. 3-5$ part at Napa/AZ/O'Reilys.
RED TAHOE LS
Rossville, Georgia USA
So I found a guy on Craigslist selling a 94 Tahoe for 2500 I test drove it today I love it but the thing is the steering is really loose I'm mechanically inclined I'm just wondering if it's worth buying and fixing or is fixing it gonna cost me what I payed for it so help me decide if I should get it or not
thing is the steering is really loose. That could be an expensive repair and that could put you over market value. JMHO and good luck.
David g......:)
LBDelaney
Texes?
Then it should be rust free that alone is worth it..
I have two 97 sC1500 one with 250k and another with 295k
One is rusted out but rebuilt motor and trans and the 295k still all OE not touched some rust but not bad.. would give that just for a rust free body.
Back N Black
Houma, LA
Doesn't look bad, and it's not a terrible price. First rule of buying any vehicle, new OR used, talk them down, they will always take less. Sounds like you could fix the issues the truck has, and make a pretty truck out of it. Go for it!
Yukonultimate23
