Hi Guys,
My center high mounted stop light or third brake light is not working. I have searched this forum to no avail. The light originally flashing when I braked and had the turn indicator on.Now it does not work at all.Since my cruise control does not work along with the third light I replaced the brake light switch on the brake pedal as suggested in multiple threads. No change for either. I checked the fuse in the fuse box(engine bay) visually and with a multi meter. The fuse was good and had continuity. There was no volts across the fuse junction with the brakes on.
I checked the voltage at the connection in the top of the tailgate and there was about .74 of a volt. I attached a test light and it did not light up. I checked the continuity of the third brake light bar at the same connection and it did not chime but the reading was about 750. I attached a nine volt battery to third brake light and it worked.
I am at a loss. Any help would be greatly appreciated.
Thanks,
Chibluz
Thanks,
Chibluz
