Three random shut offs while slowing to a red light.
petethepug
Michael
SoCal
Correct, pellets won’t stop the flow, but they will obstruct the line and gather at the point of highest velocity. When velocity slows, volume decreases at a huge factor from the obstruction.
If, and I say if, you have rouge pellets in the system, your engine will starve of fuel at idle. Once the suction of the fuel pump stops calling all the pellets together, the obstruction falls apart. Viola, all is back to normal without any DTC being triggered.
olliec420
olliec420
WHich line are you thinking? from tank to rail?
petethepug
Michael
SoCal
That & the swirl pot that the f/p lives in, as well as the mesh filter or what’s left of it on the base, if GM installed that version in your truck.
Fless
Super Moderator
Elev 5,280
Generally speaking, short term fuel trims would be used for vacuum leak diagnostics. Document the STFTs at idle, then at 1500 or 2000 rpm and compare.
Higher positive STFTs at idle (say, >+10% or so) can indicate unmetered air getting in past the MAF and the O2 sensors trying to manage that, dumping fuel into the engine.
If the STFTs get significantly lower at higher rpms, a vacuum leak is likely. This is because the higher rpm needs more air, and the vacuum leak can add only a small bit of air -- enough, though, to impact the trims at idle. At higher rpms most of the needed air comes through the proper passages and is metered more correctly.
The LTFTs are learned at various rpms and load conditions. Your true total fuel trim (on one bank) is the sum of the STFT and the LTFT at a given rpm (after the rpms have settled). If STFT is -3% and LTFT is +4%, the net FT is +1. Total single bank fuel trim of 5% or under is ideal; be concerned when it's over 10%.
olliec420
olliec420
The LTFTs are learned at various rpms and load conditions. Your true total fuel trim (on one bank) is the sum of the STFT and the LTFT at a given rpm (after raising the rpms). If STFT is -3% and LTFT is +4%, the net FT is +1. Total single bank fuel trim of 5% or under is ideal; be concerned when it's over 10%.
STFT at idle (when I've measured) are no where near 10, like 1% or less. BUT is it POSSIBLE that the EVAP valve or something like that is staying open or partially open intermittently as I'm having intermittent problems?
I dont think a permanent leak such as a crack in a plastic hose or something would show intermittent symptoms that Im seeing.
olliec420
olliec420
Just an update, changed the positive and negative cables 2-3 weeks ago and it has not happened again... yet.
Fingers crossed!
nwalk7800
