throttle body fun
black95
Freeport,NY
so for a while my truck has been running like shit with an iac code. changed that, no luck . the other day while cleaning the motor i sprayed gum cuttter on the intake to clean it, when i did this the rpms jumped, so i did it again until the point which it stalled out. turns out i had a vacuum leak ,the throttle body gasket took a crap which gave me rough/high idle (1100 rpm) in gear and a very rich idle. did the gasket last night and it runs great, no light idles at 600 in gear and does not run rich my frutration is over now to the egr problem
haks310
Got LEDs?
SoCal
I think that is about the most common problem causing a high idle.
What is wrong with your EGR? Have you checked it out?
black95
black95
Freeport,NY
a little i need a vac pump/gauge but think i just need to replace the valve i keep the vac solenoid unplugged because it runs like it has cam in it at 1500-2000rpm when it is plugged in.also i get an egr malfunction code on the parkway
knotty
where are you located at ?
crabb13
Was it very hard to change out the gasket? I believe I am having the same issue.
black95
black95
Freeport,NY
took literalyy 10 minutes and cost 8 bucks just make sure u have all of the old gasket off of the intake and some gets stuck to the bottom of the throttle body also it is only 3 bolts
TIM Z
DMAX Power
Navarre Ohio
Cool that you got it fixed, high idle/rough at a light sucks!
I have a slight stumble when stopped at a light, just wandering if its a characteristic of the TBI.
black95
black95
Freeport,NY
if it is idling low than most likely not, miine idles low but has a little occasional stumble idling at lights that is the next project
Champ74
