ccapehartusarmyINF.(ret)
good or no good that tie rod looks like poop
Moogs are greatMoogs ok, or Rare Parts?
Moogs are great
Why did you go with Mevotec? I've never heard of them. Moog also has a lifetime warranty and although they're a bit more expensive than the Mevotec, like you said you're paying a lot in labor. You don't want to pay that twice if parts go bad. Warranty doesn't cover labor.Just ordered upper and lower control arms, inner and outer tire rods, new pitman arm and idler arms, along with the idler arm bracket and upper and lower ball joints from RockAuto.
Didn't go with the moogs, went with the MevoTec line they have. Looks pretty beefy, and they have a lifetime warranty on their Supreme and Terrain series of parts.
Arrived today, dropping it off at the shop tomorrow for a Saturday install. Probably going to run me at least $600 in labor
Curious...why did you order all those parts before checking to see if you needed them?Didn't matter..... up it went on the lift, and the tech pulled and pried at EVERYTHING..... not a bit of play, anywhere.... all the parts are going back to RockAuto... cost me $38 is shipping both ways, but saved me about $1100 in parts and labor.
My popping was from my idler and pitman arm,160,000 miles,changed them ,aligned and now drives great,quiet,and no swaying back and forth going down the highway .Spend the extra few bucks for the heavy duty ones also.My friend has went through 2 ea of the cheap eBay ones and lots of hrs to change them,fyi
